Hi Erik,
If you enable the Axis then the Servo is constantly writing values so whatever you write will be immediately overwritten.
Message: 3874 |
Date: 2/12/2012 |
Subject: Re: Enabling axis prevents open loop BLDC movement |
Ah, this is good to know. It makes sense now, but I was not aware that enabling an axis had anything to do with the Servo thread, I thought it was more of turning on a CE (chip enable) or something else "hardware-ish". Thanks for the tip.
> Hi Erik,
> From: quelisto <quelisto@...>
> Sent: Sunday, February 12, 2012 6:05 PM
> Subject: [DynoMotion] Enabling axis prevents open loop BLDC movement
> Tom: I finally traced back the issue with my original program. When I added the line chX->Enable = False, everthing started working.
> Why would this be the case? What does enabling of an axis do to prevent WritePH3 from being able to execute properly?
